System Administration Guide, Volume I
Default Command Options
If you run the ufsdump command without any options, use this syntax:
# ufsdump files-to-back-up
ufsdump uses these options, by default:
ufsdump 9uf /dev/rmt/0 files-to-back-up
These options do a level 9 incremental backup to the default tape drive at its preferred density.
