The syntax of the ufsrestore command is:
ufsrestore [options][arguments][filename ...] |
options |
Is a single string of one-letter option names. You must choose one and only one of these options: i, r, R, t, or x. |
arguments |
Follows the option string with the arguments that match the options. The option names and the arguments that go with them must be in the same order. |
filename |
Specifies files to be restored as arguments to the x or t options, and must always come last. |
