System Administration Guide, Volume I
Example--Determining Which Tapes to Use
If you use ufsdump to dump the /usr file system, the table of contents lists only the files and directories under /usr. The following example checks if /usr/bin/pwd is in the online archive.
# ufsrestore ta archive-name ./bin/pwd
The following example checks if /usr/bin/pwd is on the backup tape.
# ufsrestore tf /dev/rmt/n ./bin/pwd
