Become superuser.
Write-protect the tape for safety.
Insert the volume 1 tape into the tape drive.
Change to a directory for restoring files temporarily.
# cd /var/tmp |
To avoid conflicts with other users, you may want to create and change to a subdirectory, such as /var/tmp/restore, in which to restore the files.
If you are restoring a hierarchy, you should restore the files in a temporary directory on the same file system where the files will reside, so you can use the mv command to move the entire hierarchy where it belongs after it is restored.
Use the ufsrestore command to restore the file.
# ufsrestore xvf /dev/rmt/n filename ... |
x |
Tells ufsrestore to copy specific files or directories in the filename argument. |
v |
Displays the file names as they are restored. |
f /dev/rmt/n |
Identifies the tape device name. |
filename ... |
One or more individual file or directory names separated by spaces, for example: ./export/home/user1/mail ./export/home/user2/mail. |
Type the volume number where files are located and press Return.
Specify next volume #: 1 |
The file is restored to the current working directory.
To keep the mode of the current directory unchanged, type n and press Return at the set owner/mode prompt.
set owner/mode for '.'? [yn] n |
Verify the restored files.
The following example restores the passwd and shadow files to the /var/tmp directory.
# cd /var/tmp # ufsrestore xvf /dev/rmt/0 ./etc/passwd ./etc/shadow Verify volume and initialize maps Media block size is 126 Dump date: Tue Jun 09 14:30:16 1998 Dumped from: the epoch Level 0 dump of / on pluto:/dev/dsk/c0t3d0s0 Label: none Extract directories from tape Initialize symbol table. Warning: ./etc: File exists Extract requested files You have not read any volumes yet. Unless you know which volume your file(s) are on you should start with the last volume and work towards the first. Specify next volume #: 1 extract file ./etc/passwd Add links Set directory mode, owner, and times. set owner/mode for `.'? [yn] n Directories already exist, set modes anyway? [yn] n # cd etc # mv passwd /etc # mv shadow /etc # ls -l etc |
