System Administration Guide, Volume I
How to Copy Directories Between File Systems (cpio)
  1. Become superuser.
  2. Change to the appropriate directory.
    # cd filesystem1
  3. Copy the directory tree from filesystem1 to filesystem2 by using a combination of the find and cpio commands.
    # find . -print -depth | cpio -pdm filesystem2
    Starts in the current working directory.
    -print
    Prints the file names.
    -depth
    Descends the directory hierarchy and prints file names on the way back up.
    -p
    Creates a list of files.
    -d
    Creates directories as needed.
    -m
    Sets the correct modification times on directories.
    The files from the directory name you specify are copied, and symbolic links are preserved.
    You may also specify the -u option. This option forces an unconditional copy. Otherwise older files will not replace newer files. This may be useful if an exact copy of a directory is desired, and some of the files being copied may already exist in the target directory.
  4. Verify the copy was successful by displaying the destination directory contents.
    # cd filesystem2
    # ls
  5. If appropriate, remove the source directory.
    # rm -rf filesystem1
Example--Copying Directories Between File Systems (cpio)
# cd /data1
# find . -print -depth | cpio -pdm /data2
19013 blocks
# cd /data2
# ls
# rm -rf /data1
See cpio(1) for more information.
