System Administration Guide, Volume I
How to Retrieve bar Files From a Diskette
  1. Change to the directory where you want to put the files.
  2. Insert the diskette into the drive.
  3. Run volcheck to make the diskette available.
    $ volcheck
  4. Use the cpio command to retrieve bar files from a diskette.
    All the files on the diskette are copied to the current directory.
    $ cpio -ivH bar < /vol/dev/rdiskette/unlabeled
