System Administration Guide, Volume I
How to List the Files on a Diskette (tar)
  1. Insert a diskette into the drive.
  2. Run volcheck to make the diskette available.
    $ volcheck
  3. Use the tar command to list the files on a diskette.
    $ tar tvf /vol/dev/rdiskette0/unlabeled
Example--Listing the Files on a Diskette (tar)
The following example lists the files on a diskette.
rw-rw-rw-6693/10  44032 Jun  9 15:45 evaluation.doc
rw-rw-rw-6693/10  43008 Jun  9 15:55 evaluation.doc.backup
See tar(1) for more information.
If you need a multiple-volume interchange utility, use the cpio command. The tar command is only a single-volume utility.
