Normally, you specify a tape drive by its logical unit number, which may run from 0 to n. Table 38-3 describes how to specify tape device names using default density settings.
Table 38-3 Specifying Default Densities for a Tape Drive|
To Specify The ... |
Use ... |
First drive, rewinding |
/dev/rmt/0 |
First drive, nonrewinding |
/dev/rmt/0n |
Second drive, rewinding |
/dev/rmt/1 |
Second drive, nonrewinding |
/dev/rmt/1n |
By default, the drive writes at its "preferred" density, which is usually the highest density it supports. If you do not specify a tape device, the command writes to drive number 0 at the default density the device supports.
