The following steps provide the general steps for backing up file systems using the ufsdump command. The examples show specific uses of options and arguments.
Become superuser.
Bring the system to run level S (single-user mode).
# shutdown -g30 -y |
[Optional] Check the file system for consistency with the fsck command.
Running the fsck -m command checks for consistency of file systems. For example, power failures can leave files in an inconsistent state. For more information on the fsck command, see Chapter 31, Checking File System Integrity.
# fsck -m /dev/rdsk/ device-name |
If you need to back up file systems to a remote tape drive:
On the system to which the tape drive is attached (the tape server), add the following entry to its /.rhosts file.
host root |
host |
Specifies the name of the system on which you will run ufsdump to perform the backup. |
On the tape server, verify that the host added to the /.rhosts file is accessible through the name service.
Identify the device name of the tape drive.
The default tape drive is /dev/rmt/0.
Insert a tape that is not write protected into the tape drive.
Back up file systems using the ufsdump command.
Use the following table to select the most common options and arguments for the ufsdump command. See Chapter 36, The ufsdump and ufsrestore Commands (Reference) for other options and arguments.
To ... |
Use This Option or Argument ... |
For Example ... |
See ... |
Do a full backup |
0 option |
ufsdump 0ucf /dev/rmt/0 / | |
Do an incremental backup |
1-9 option |
ufsdump 9ucf /dev/rmt/0 / | |
Back up individual files |
Specify a file or directory |
ufsdump ucf /dev/rmt/0 /export/home/kryten |
Record dumps to /etc/dumpdates file |
-u option |
ufsdump 9ucf /dev/rmt/0 /export/home | |
Specify a cartridge tape |
-c option |
Specify the tape drive |
-f dump-file |
Back up local file systems to a remote system's tape device |
remote-system:dump-file |
ufsdump 0ucf pluto:/dev/rmt/0 /export/home |
"Example--Full Backup to Remote System (Solaris 2.6 Data to Solaris 7 System)" |
If prompted, remove the tape and replace with the next volume.
Label each tape with the volume number, level, date, system name, disk slice, and file system.
Bring the system back to run level 3 by pressing Control-d.
Verify the backup was successful by using the ufsrestore command to display the tape contents.
This command is described in Chapter 35, Restoring Files and File Systems (Tasks).
The following example shows a full backup of the root (/) file system to a QIC-150 tape (/dev/rmt/0).
# shutdown -g30 -y
# ufsdump 0ucf /dev/rmt/0 /
DUMP: Writing 63 Kilobyte records
DUMP: Date of this level 0 dump: Tue Jun 09 10:14:54 1998
DUMP: Date of last level 0 dump: the epoch
DUMP: Dumping /dev/rdsk/c0t3d0s0 (pluto:/) to /dev/rmt/0.
DUMP: Mapping (Pass I) [regular files]
DUMP: Mapping (Pass II) [directories]
DUMP: Estimated 73708 blocks (35.99MB).
DUMP: Dumping (Pass III) [directories]
DUMP: Dumping (Pass IV) [regular files]
DUMP: Tape rewinding
DUMP: 73582 blocks (35.93MB) on 1 volume at 100 KB/sec
DUMP: DUMP IS DONE
DUMP: Level 0 dump on Tue Jun 09 10:14:54 1998
# ufsrestore tf /dev/rmt/0
2 .
3 ./lost+found
5696 ./usr
11392 ./export
17088 ./export/home
22784 ./export/root
28480 ./export/swap
34176 ./opt
39872 ./var
45568 ./var/sadm
51264 ./var/sadm/install
56960 ./var/sadm/install/admin
57011 ./var/sadm/install/admin/default
(Press Control-d to bring system to run level 3)
The following example shows an incremental backup of the root (/) file system to a 4-mm DAT tape (/dev/rmt/0).
# ufsdump 9ucf /dev/rmt/0 /
DUMP: Date of this level 9 dump: Tue Jun 09 11:04:41 1998
DUMP: Date of last level 0 dump: Tue Jun 09 10:14:54 1998
DUMP: Estimated 1502 blocks (751KB).
DUMP: 1384 blocks (692KB) on 1 volume at 51 KB/sec
DUMP: DUMP IS DONE
DUMP: Level 9 dump on Tue Jun 09 11:04:41 1998
39872 ./var
62671 ./var/adm
39915 ./var/adm/sa
40018 ./var/adm/sa/sa09
62810 ./var/adm/sulog
62888 ./var/adm/pacct
91154 ./var/cron
91311 ./var/cron/log
5716 ./var/mail
5835 ./var/mail/adm
45585 ./var/spool
51388 ./var/spool/mqueue
91155 ./var/tmp
The following example shows a full backup of the /export/home/kryten directory to a 4-mm DAT tape.
# ufsdump 0ucf /dev/rmt/0 /export/home/kryten
DUMP: Date of this level 0 dump: Tue Jun 09 11:12:44 1998
DUMP: Dumping /dev/rdsk/c0t3d0s7 (pluto:/export/home) to /dev/rmt/0.
DUMP: Estimated 232 blocks (116KB).
DUMP: 124 blocks (62KB) on 1 volume at 8 KB/sec
DUMP: DUMP IS DONE
2 .
2688 ./kryten
5409 ./kryten/letters
5410 ./kryten/letters/letter1
5411 ./kryten/letters/letter2
5412 ./kryten/letters/letter3
2689 ./kryten/.profile
8096 ./kryten/memos
30 ./kryten/reports
31 ./kryten/reports/reportA
32 ./kryten/reports/reportB
33 ./kryten/reports/reportC
The following example shows a full backup of a local /export/home file system on a Solaris 2.6 system to a tape device on a remote Solaris 7 system called pluto.
# ufsdump 0ucf pluto:/dev/rmt/0 /export/home
DUMP: Date of this level 0 dump: Tue Jun 09 13:54:27 1998
DUMP: Dumping /dev/rdsk/c0t3d0s7 (venus:/export/home) to pluto:/dev/rmt/0.
DUMP: Estimated 38310 blocks (18.71MB).
DUMP: 38302 blocks (18.70MB) on 1 volume at 98 KB/sec
DUMP: DUMP IS DONE
DUMP: Level 0 dump on Tue Jun 09 13:54:27 1998
# # ufsrestore tf pluto:/dev/rmt/0
2 .
3 ./lost+found
34180 ./kryten
34182 ./kryten/.login
34183 ./kryten/.cshrc
51266 ./kryten/letters
51272 ./kryten/letters/letter1
51273 ./kryten/letters/letter2
51274 ./kryten/letters/letter3
57032 ./kryten/memos
74095 ./kryten/reports
74096 ./kryten/reports/reportA
74097 ./kryten/reports/reportB
74098 ./kryten/reports/reportC
The following example shows a full backup of a local /export/home file system on a Solaris 7 system to a tape device on a remote SunOS 4.1.3 system (mars).
Notice the SunOS 4.x-style device name (/dev/rst0) used with the ufsdump command.
# ufsdump 0ucf mars:/dev/rst0 /export/home
DUMP: Date of this level 0 dump: Fri Oct 24 15:06:47 1997
DUMP: Dumping /dev/rdsk/c0t3d0s7 (earth:/export/home) to (mars:/dev/rst0).
DUMP: mapping (Pass I) [regular files]
DUMP: mapping (Pass II) [directories]
DUMP: estimated 19574 blocks (9.56MB)
DUMP: dumping (Pass III) [directories]
DUMP: dumping (Pass IV) [regular files]
DUMP: level 0 dump on Fri Oct 24 15:06:47 1997
DUMP: 19574 blocks (9.56MB) on 1 volume
DUMP: DUMP IS DONE
ufsrestore tf mars:/dev/rst0
2 .
3 ./lost+found
2688 ./kryten
8096 ./kryten/memos
30 ./kryten/reports
The following example shows a full backup of a local root (/) file system on a Sun 4.1.3 system (mars) to a remote tape device on a Solaris 7 system called pluto.
Notice that when you back up data on a system running SunOS 4.1.3 or a compatible version, you must use the dump command--not the ufsdump command.
# dump 0ucf pluto:/dev/rmt/0 /
DUMP: Date of this level 0 dump: Tue Oct 21 16:05:19 1997
DUMP: Dumping /dev/rsd2a (/) to /dev/rmt/0 on host pluto
DUMP: estimated 8686 blocks (4.24MB) on 0.10 tape(s).
DUMP: level 0 dump on Tue Oct 21 16:05:19 1997
DUMP: 8690 blocks (4.24MB) on 1 volume
DUMP: DUMP IS DONE
# restore tf pluto:/dev/rmt/0
2 .
3 ./lost+found
3776 ./export
7552 ./home
11328 ./usr
15104 ./pcfs
3777 ./tftpboot
3778 ./tftpboot/tftpboot
3794 ./tftpboot/boot.sun4c.sunos.4.1.3
7553 ./etc
7554 ./etc/sendmail.cf
7555 ./etc/aliases
7556 ./etc/aliases.dir
7557 ./etc/aliases.pag
7558 ./etc/holidays
7559 ./etc/dumpdates
