When you add a Solstice AutoClient using Host Manager, you have the option to enable scripts to run on the server before or after you add the AutoClient to the server, or run on the client before or after the cache is configured on the AutoClient.
These scripts are those that you have created to customize the addition or deletion of AutoClient systems; these scripts need to be located in the /opt/SUNWadmd/Scripts directory in order for the AdminSuite software to read them.
