Add and Maintain Support
Host Manager enables you to add and modify support for the following Solaris system types:
Solaris AutoClient systems
Solaris diskless clients
Solaris standalone systems
Solaris OS servers
JavaStations (modify support only)
Table 3-3 describes the server-client configurations that are supported by the Solstice AdminSuite 2.3 release of Host Manager.
Table 3-3 Supported Server-Client Configurations
If You Have A ...
You Can Add OS Services and Support For ...
For the Following Releases ...
x86 server running the Solaris 2.4 release and compatible versions
SPARC clients [AutoClient systems are only supported on the Solaris 2.4 release and compatible versions.]
Solaris 2.3 release and compatible versions
x86 clients
SPARC server running the Solaris 2.3 release and compatible versions
SPARC clients1
SunOS 4.1 release and compatible versions, Solaris 2.3 release and compatible versions
x86 clients
Note - The SunOS 4.1 release and compatible versions are only supported on SPARC systems with the Sun4, Sun4c, and Sun4m platform groups.
