Host Manager enables you to set up systems to provide Solaris installation services for other systems on the network. You can set up the following types of installation services on a system:
An install server - A system on the network that provides a Solaris CD image (either from a CD-ROM drive or the copy on the hard disk) for other systems to install from.
A boot server - A system that provides boot information to other systems on the network. The boot server and the install server are usually the same system.
A profile server - A system that contains Jumpstart files for systems to perform a custom JumpStart installation.
A boot server and install server are typically the same system. However, if the system to be installed is on a different subnet than the install server, a boot server is required on that subnet.
