Start Host Manager from the Solstice Launcher and select the name service, if not done already.
See "How to Start Solstice Host Manager" for more information.
Select a system entry to modify from the Host Manager main window.
Choose Modify from the Edit menu.
The Modify window contains the selected system entry.
Modify support for the system.
If you need information to change a field, click on the Help button to see field definitions for this window.
Click on OK on the Modify window.
Select Save Changes from the File menu to modify support for the system.
Verify that the system entry has been modified in the Host Manager main window.
