The following dmesg output is displayed from a SPARC system.
# dmesg SunOS Release 5.7 Version generic [UNIX(R) System V Release 4.0] Copyright (c) 1983-1998, Sun Microsystems, Inc. pac: enabled - SuperSPARC cpu0: TI,TMS390Z50 (mid 8 impl 0x0 ver 0x0 clock 40 MHz) mem = 32768K (0x2000000) avail mem = 27803648 Ethernet address = 8:0:20:1f:33:9g root nexus = SUNW,SPARCstation-10 iommu0 at root: obio 0xe0000000 sbus0 at iommu0: obio 0xe0001000 dma0 at sbus0: SBus slot f 0x400000 dma0 is /iommu@f,e0000000/sbus@f,e0001000/espdma@f,400000 /iommu@f,e0000000/sbus@f,e0001000/espdma@f,400000/esp@f,800000 (esp0): esp-options=0x46 esp0 at dma0: SBus slot f 0x800000 sparc ipl 4 esp0 is /iommu@f,e0000000/sbus@f,e0001000/espdma@f,400000/esp@f,800000 sd1 at esp0: target 1 lun 0 sd1 is /iommu@f,e0000000/sbus@f,e0001000/espdma@f,400000/esp@f,800000/sd@1,0 sd3 at esp0: target 3 lun 0 sd3 is /iommu@f,e0000000/sbus@f,e0001000/espdma@f,400000/esp@f,800000/sd@3,0 root on /iommu@f,e0000000/sbus@f,e0001000/espdma@f,400000/esp@f,800000/sd@3,0:a ... obio0 at root obio0 at obio0: obio 0x100000 sparc ipl 12 zs0 is /obio/zs@0,100000 obio1 at obio0: obio 0x0 sparc ipl 12 zs1 is /obio/zs@0,0 cpu 0 initialization complete - online ledma0 at sbus0: SBus slot f 0x400010 le0 at ledma0: SBus slot f 0xc00000 sparc ipl 6 le0 is /iommu@f,e0000000/sbus@f,e0001000/ledma@f,400010/le@f,c00000 dump on /dev/dsk/c0t3d0s1 size 200 MB # |
The following dmesg output is displayed from an x86 system.
# dmesg SunOS Release 5.7 Version generic [UNIX(R) System V Release 4.0] Copyright (c) 1983-1998, Sun Microsystems, Inc. mem = 130684K (0x7f9f000) avail mem = 114970624 root nexus = i86pc isa0 at root ISA-device: asy0 asy0 is /isa/asy@1,3f8 ISA-device: asy1 asy1 is /isa/asy@1,2f8 pci0 at root: space 0 offset 0 IDE device at targ 0, lun 0 lastlun 0x0 model WDC AC31000H, stat 50, err 0 cfg 0x427a, cyl 2100, hd 16, sec/trk 63 mult1 0x8010, mult2 0x108, dwcap 0x0, cap 0xf00 piomode 0x180, dmamode 0x200, advpiomode 0x1 minpio 380, minpioflow 180 valid 0x3, dwdma 0x3, majver 0x0 ata_set_feature: (0x66,0x0) failed ISA-device: ata0 Disk0: cmdk0 at ata0 target 0 lun 0 cmdk0 is /isa/ata@1,1f0/cmdk@0,0 root on /isa/ata@1,1f0/cmdk@0,0:a fstype ufs Number of console virtual screens = 13 cpu 0 initialization complete - online Ethernet address = 2:7:1:1c:27:e5 . . . |
