Command names are needed as input whenever format is displaying a menu prompt. You can abbreviate the command names, as long as what you enter is sufficient to uniquely identify the command desired.
For example, use p to enter the partition menu from the format menu. Then enter p to display the current slice table.
format> p PARTITION MENU: 0 - change `0' partition 1 - change `1' partition 2 - change `2' partition 3 - change `3' partition 4 - change `4' partition 5 - change `5' partition 6 - change `6' partition 7 - change `7' partition select - select a predefined table modify - modify a predefined partition table name - name the current table print - display the current table label - write partition map and label to the disk quit partition> p |
