Boot the system to single-user mode. If necessary, boot the system from a local CD-ROM or the network in single-user mode to access the disk.
See Chapter 8, Booting a SPARC System (Tasks) or Chapter 9, x86: Booting a System (Tasks) for information on booting the system.
Use the format utility to relabel the disk.
# format |
At this point, format attempts to automatically configure any unlabeled SCSI disk. If format is able to configure the unlabeled and corrupted disk, it will display:
cwtxdy: configured with capacity of abcMB |
The format utility then displays the list of disks on the system.
Enter the number of the disk that you need to recover from the list displayed on your screen.
Specify disk (enter its number): 1 |
Use the table below to determine how to label the disk.
If the Disk was Successfully Configured ... |
If the Disk was not Successfully Configured ... |
Follow steps 5 and 6. Then go to step 12. |
Follow steps 7-11. Then go to step 12. |
Search for the backup label by using the verify command.
format> verify Warning: Could not read primary label. Warning: Check the current partitioning and 'label' the disk or use the 'backup' command. Backup label contents: Volume name = < > ascii name = <SUN0424 cyl 1151 alt 2 hd 9 sec 80> pcyl = 2500 ncyl = 1151 acyl = 2 nhead = 9 nsect = 80 Part Tag Flag Cylinders Size Blocks 0 root wm 0 - 91 32.34MB (92/0/0) 66240 1 swap wu 92 - 183 32.34MB (92/0/0) 66240 2 backup wu 0 - 1150 404.65MB (1151/0/0) 828720 3 unassigned wm 0 0 (0/0/0) 0 4 unassigned wm 0 0 (0/0/0) 0 5 unassigned wm 0 0 (0/0/0) 0 6 usr wm 184 - 1150 339.96MB (967/0/0) 696240 7 unassigned wm 0 0 (0/0/0) 0 |
If format was able to find a backup label and the backup label contents appear satisfactory, use the backup command to label the disk with the backup label.
format> backup Disk has a primary label, still continue? y Searching for backup labels...found. Restoring primary label |
The disk label has been recovered. Go to step 12.
If format was not able to automatically configure the disk, specify the disk type using the type command.
format> type |
The format utility displays the Available Drives Type menu.
Select 0 to automatically configure the disk, or select a disk type from the list of possible disk types.
Specify disk type (enter its number)[8]: 8 |
If the disk was successfully configured, reply with no when format asks if you want to label the disk.
Disk not labeled. Label it now? no |
Use the verify command to search for backup labels.
format> verify Warning: Could not read primary label. Warning: Check the current partitioning and 'label' the disk or use the 'backup' command. . . . |
Exit the format utility by typing q.
format> q |
Verify the file systems on the recovered disk by using the fsck command.
See Chapter 31, Checking File System Integrity for information about using the fsck command.
