Become superuser.
# format |
Enter the number of the disk that you want to check from the list displayed on your screen.
Specify disk (enter its number): 0 |
Verify that the disk you chose is formatted by identifying the following message.
[disk formatted] |
The following example shows that disk c0t3d0 is formatted.
# format
AVAILABLE DISK SELECTIONS:
0. c0t1d0 <SUN1.05 cyl 2036 alt 2 hd 14 sec 72>
/iommu@f,e0000000/sbus@f,e0001000/espdma@f,400000/esp@f,800000/sd@1,0
1. c0t3d0 <SUN1.05 cyl 2036 alt 2 hd 14 sec 72>
/iommu@f,e0000000/sbus@f,e0001000/espdma@f,400000/esp@f,800000/sd@3,0
selecting c0t1d0
[disk formatted]
