Check the following table if the format utility did not recognize the disk.
If the Disk ... |
Then ... |
Is newly added and you didn't perform a reconfiguration boot |
Go to Chapter 23, SPARC: Adding a Disk (Tasks) or Chapter 24, x86: Adding a Disk (Tasks). |
Is a third-party disk | |
Label was corrupted by a system problem, such as a power failure |
Go to "How to Label a Disk". |
Is not properly connected to the system |
Connect the disk to the system using your disk hardware documentation. |
