Make sure you have read "x86: Guidelines for Creating an fdisk Partition".
Become superuser.
Start the format(1M) utility.
# format |
Enter the number of the disk on which to create a Solaris fdisk partition from the list displayed on your screen.
Specify disk (enter its number): disk-number |
disk-number |
Is the number of the disk on which to create a Solaris fdisk partition. |
Go into the fdisk menu.
format> fdisk |
The fdisk menu displayed is dependent upon whether the disk has existing fdisk partitions. Determine the next step using the following table.
If You Want To ... |
Go To ... |
See ... |
Create a Solaris fdisk partition to span the entire disk. |
Step 6 |
"x86: Example--Creating a Solaris fdisk Partition That Spans the Entire Drive" |
Create a Solaris fdisk partition and preserve existing non-Solaris fdisk partition(s). |
Step 7 |
"x86: Example--Creating a Solaris fdisk Partition and Preserving an Existing fdisk Partition" |
Create a Solaris fdisk partition and additional non-Solaris fdisk partition(s). |
Step 7 |
"x86: Example--Creating a Solaris fdisk Partition and an Additional fdisk Partition" |
Create and activate a Solaris fdisk partition spanning the entire disk by specifying y at the prompt. Then go to step 14.
The recommended default partitioning for your disk is: a 100% "SOLARIS System" partition. To select this, please type "y". To partition your disk differently, type "n" and the "fdisk" program will let you select other partitions. y |
Specify n at the prompt if you do not want the Solaris fdisk partition to span the entire disk.
select other partitions. n
Total disk size is 2694 cylinders
Cylinder size is 765 (512 byte) blocks
Cylinders
Partition Status Type Start End Length %
THERE ARE NO PARTITIONS CURRENTLY DEFINED SELECT ONE OF THE
FOLLOWING:
1. Create a partition
2. Change Active (Boot from) partition
3. Delete a partition
4. Exit (Update disk configuration and exit)
5. Cancel (Exit without updating disk configuration)
Enter Selection:
Select option 1, Create a partition, to create an fdisk partition.
Cylinders
FOLLOWING:
Enter Selection: 1
Create a Solaris fdisk partition by selecting 1(=Solaris).
Indicate the type of partition you want to create (1=SOLARIS, 2=UNIX, 3=PCIXOS, 4=Other, 8=DOSBIG) (5=DOS12, 6=DOS16, 7=DOSEXT, 0=Exit) ? 1 |
Identify the percentage of disk to be reserved for the Solaris fdisk partition. Keep in mind the size of any existing fdisk partitions when calculating this percentage.
Indicate the percentage of the disk you want this partition to use (or enter "c" to specify in cylinders). nn |
Activate the Solaris fdisk partition by typing y at the prompt.
Do you want this to become the Active partition? If so, it will be activated each time you reset your computer or when you turn it on again. Please type "y" or "n". y |
The Enter Selection: prompt is displayed afer the fdisk partition is activated.
Select option 1, Create a partition, to create another fdisk partition.
See steps 9-11 for instructions on creating an fdisk partition.
Update the disk configuration and exit the fdisk menu from the selection menu.
Selection: 4 |
Relabel the disk using the label command.
WARNING: Solaris fdisk partition changed - Please relabel the disk format> label Ready to label disk, continue? yes format> |
format> quit |
After you create a Solaris fdisk partition on the disk, you can create slices on the disk. Go to "x86: How to Create Disk Slices and Label a Disk".
The following example uses the format's utility's fdisk option to create a Solaris fdisk partition that spans the entire drive.
# format
Searching for disks...done
AVAILABLE DISK SELECTIONS:
0. c0t0d0 <DEFAULT cyl 1479 alt 2 hd 7 sec 79>
/eisa/eha@1000,0/cmdk@0,0
1. c0t2d0 <SUN1.05 cyl 2692 alt 2 hd 9 sec 85>
/eisa/eha@1000,0/cmdk@2,0
Specify disk (enter its number): 1
selecting c0t2d0
[disk formatted]
format> fdisk
format> label
format> quit
The following example describes how to create a Solaris fdisk partition on a disk that has an existing DOS-BIG fdisk partition.
format> fdisk
Cylinders
1 DOS-BIG 1 538 538 20
SELECT ONE OF THE FOLLOWING:
Enter Selection: 1
(5=DOS12, 6=DOS16, 7=DOSEXT, 0=Exit) ?1
to use (or enter "c" to specify in cylinders). 80
Partition 2 is now the Active partition Total disk size is 2694
cylinders
Cylinders
2 Active SOLARIS 539 2693 2155 80
Enter Selection: Selection: 4
format> label
format> q
This following example describes how to create a Solaris fdisk partition and a DOSBIG fdisk partition.
format> fdisk
Cylinders
THERE ARE NO PARTITIONS CURRENTLY DEFINED SELECT ONE OF THE FOLLOWING:
Enter Selection: 1
(5=DOS12, 6=DOS16, 7=DOSEXT, 0=Exit) ?8
to use (or enter "c" to specify in cylinders). 20
again. Please type "y" or "n". n
Cylinders
5. Cancel (Exit without updating disk configuration)Enter
Selection: 1
cylinders
Cylinders
Enter Selection: 4
format> q
