Become superuser.
Create a file system for each slice with the newfs(1M) command.
# newfs /dev/rdsk/cwtxdysz |
/dev/rdsk/cwtxdysZ |
Raw device for the file system to be created. |
See Chapter 28, Mounting and Unmounting File Systems (Tasks) for more information about the newfs command.
Verify the new file system by mounting it on an unused mount point.
# mount /dev/dsk/cwtxdysz /mnt # ls /mnt lost+found |
If You Are Adding A ... |
Then ... |
System Disk |
You need to restore the root (/) and /usr file systems on the disk. Go to Chapter 35, Restoring Files and File Systems (Tasks). After the root (/) and /usr file systems are restored, install the boot block. Go to "x86: How to Install a Boot Block on a System Disk". |
Secondary Disk |
You may need to restore file systems on the new disk. Go to Chapter 35, Restoring Files and File Systems (Tasks).
If you are not restoring file systems on the new disk, you are finished adding a secondary disk. See Chapter 28, Mounting and Unmounting File Systems (Tasks) for information on making the file systems available to users. |
