Follow these guidelines when setting up the fdisk partition.
The disk can be divided into a maximum of four fdisk partitions. One of these partitions must be a Solaris partition.
The Solaris partition must be made the active partition on the disk. The active partition is the one whose operating system will be booted by default at system start-up.
Solaris fdisk partitions must begin on cylinder boundaries.
Solaris fdisk partitions must begin at cylinder 1, not cylinder 0, on the first disk because additional boot information, including the master boot record, is written in sector 0.
The Solaris fdisk partition can be the entire disk or you may want to make it smaller to allow room for a DOS partition. You can also make a new fdisk partition on a disk without disturbing existing partitions (if there is enough room to create a new one).
Solaris slices are sometimes called partitions. This user guide uses the term slice, but some Solaris documentation and programs may refer to a slice as a partition. To avoid confusion, Solaris documentation tries to distinguish between fdisk partitions (which are supported only on SolarisTM (Intel Platform Edition) and the divisions within the Solaris fdisk partition, which may be called slices or partitions.
