Become superuser.
Unmount the cached file system.
# umount mount-point |
mount-point specifies the cached file system that you want to delete.
Determine the cache ID from the cfsadmin -l output, as follows:
# cfsadmin -l cache-directory cfsadmin: list cache FS information maxblocks 90% minblocks 0% threshblocks 85% maxfiles 90% minfiles 0% threshfiles 85% maxfilesize 3MB cache-ID # |
Delete a cached file system from a specified cache.
# cfsadmin -d cache-id cache-directory |
cache-id |
Indicates the name of the cached file system, which is the last line of the cfsadmin -l output. See "How to Display Information About Cached File Systems" for more information. You can delete all the cached file systems in a particular cache by specifying all for cache-id. |
cache-directory |
Specifies the directory where the cache resides. |
Verify that the file system has been deleted.
The cache ID of the file system you just deleted should be missing from the output of the following command. Refer to cfsadmin(1M) for more information about the fields specified in the command output.
# cfsadmin -l cache-directory cfsadmin: list cache FS information maxblocks 90% minblocks 0% threshblocks 85% maxfiles 90% minfiles 0% threshfiles 85% maxfilesize 3MB # |
The following example unmounts a cached file system and deletes the cached file system from the cache.
# umount /docs # cfsadmin -d merlin:_docs:_docs /local/mycache |
The following example deletes all the cached file systems in the /local/mycache cache. This also deletes the cache.
# cfsadmin -d all /local/mycache |
