System Administration Guide, Volume I
How to Mount a File System in a Cache by Editing the /etc/vfstab File
  1. Become superuser.
  2. Using an editor, specify the file systems to be mounted in the /etc/vfstab file:
    #device     device             mount  FS    fsck  mount   mount
    #to mount     to fsck            point  type  pass  at boot options
    /dev/dsk/devicename /dev/rdsk/devicename /mount-point cachefs  2    yes  -
    This line represents the new entry.
  3. Mount the cached file system using the mount command, as follows:
    # mount /mount-point
    or reboot.
Example--Mounting a File System in a Cache by Editing the /etc/vfstab File
The following example shows the /etc/vfstab entry for the cache file system.
/dev/dsk/c0t1d0s0 /dev/rdsk/c0t1d0s0 /usr/local cachefs  2   yes     -
The /usr/local directory is mounted in the cache directory.
# mount /usr/local
