View the statistics with the cachefsstat(1M) command. You can do this at any time. For example, you do not have to set up logging in order to view the statistics.
$ cachefsstat mount-point |
mount-point |
Specifies the cached file system for which you want to view the statistics. |
If you do not specify the mount point, statistics for all mounted CacheFS file systems will be displayed.
$ cachefsstat /home/sam cache hit rate: 73% (1234 hits, 450 misses) consistency checks: 700 (650 pass, 50 fail) modifies: 321 garbage collection: 0 |
