To pack files from a shared directory, and to ensure that you pack only those files that you own, define the LIST command within the packing list file as follows:
LIST !find . -user your_user_name -print |
Pack the packing list in the cache using the cachefspack -sf command.
$ cachefspack -sf packing_list |
-s |
Adjusts the output of the find command to be suitable for the packing list. |
-f |
Specifies a packing list to read. |
filename |
Specifies the name of the packing list to read. |
The -s option must be used with the -f option. The -s option cannot be used alone.
The following example shows how to define a LIST command in the packing list to pack only the files from the base directory that you own:
LIST !find . -user jones -print |
The following example shows how you would then specify packing the packing list.
$ cachefspack -sf /projects/proj_1 |
