Unpack files or packing lists from the cache using the -u or -U option of the cachefspack command.
$ cachefspack -u filename | -U cache-directory |
-u |
Specifies that you want the file or files unpacked. You must specify a filename with this option. |
filename |
Specifies the name of the file or packing list you want unpacked in the cache. For more information about the cachefspack command, see the man page. |
-U |
Specifies that you want to unpack all files in the cache. |
The following example shows the file /usr/openwin/bin/xlogo specified to be unpacked from the cache.
$ cachefspack -u /usr/openwin/bin/xlogo |
The following example shows several files specified to be unpacked from the cache.
$ cd /usr/openwin/bin $ cachefspack -u xlogo xview xcolor |
You can also unpack a packing list, which is a file that contains the path to a directory of files, as follows:
$ cachefspack -uf list.pkg |
The following example uses the -U option to specify all files in a cache directory to be unpacked.
$ cachefspack -U /local/mycache |
You cannot unpack a cache that does not have at least one file system mounted. With the -U option, if you specify a cache that does not contain mounted filesystems, you will see output similar to the following:
$ cachefspack -U /local/mycache cachefspack: Could not unpack cache /local/mycache, no mounted filesystems in the cache. |
