Pack files in the cache using the cachefspack command.
$ cachefspack -p filename |
-p |
Specifies that you want the file or files packed. This is also the default. |
filename |
Specifies the name of the file or directory you want packed in the cache. When you specify a directory, all of its subdirectories are also packed. For more information, see cachefspack(1M). |
The following example shows the file projects specified to be packed in the cache.
$ cachefspack -p projects |
The following example shows several files specified to be packed in the cache.
$ cachefspack -p projects updates master_plan |
The following example shows a directory specified to be packed in the cache.
$ cachefspack -p /usr/openwin/bin |
