To make a new file system on a disk slice, you almost always use the newfs command. Table 27-1 shows the default parameters used by the newfs command.
Table 27-1 Default Parameters Used by the newfs Command|
Parameter |
Default Value |
Block size |
8 Kbytes |
Fragment size |
1 Kbyte |
Minimum free space |
((64 Mbytes/partition size) * 100), rounded down to the nearest integer and limited between 1% and 10%, inclusively |
Rotational delay |
Device-dependent |
Optimization type |
Space |
Number of inodes |
1 for each 2 Kbytes of disk space |
