Become superuser.
If necessary, create the directory where you want to mount the TMPFS file system and set permissions and ownership as necessary.
Create a TMPFS file system.
To set up the system to automatically create a TMPFS file system when it boots, see "Example--Creating a TMPFS File System at Boot Time".
# mount -F tmpfs -o size=number swap mount-point |
size=number |
Specifies the size of the TMPFS file system in Mbytes. |
mount-point |
The directory on which the TMPFS file system is mounted. |
Look at the output from the mount command to verify that the TMPFS file system has been created.
# mount -v |
The following example creates a new directory, /export/reports, and mounts a TMPFS file system at that point, limiting it to 50 Mbytes.
# mkdir /export/reports # chmod 777 /export/reports # mount -F tmpfs -o size=50 swap /export/reports |
You can set up the system to automatically create a TMPFS file system when it boots by adding an entry to the /etc/vfstab file. The following example shows an entry in the /etc/vfstab file that will create a TMPFS file system on /export/test when the system boots. Since the size=number option is not specified, the size of the TMPFS file system on /export/test is limited only by the available system resources.
swap - /export/test tmpfs - yes - |
For more information the /etc/vfstab file, see "/etc/vfstab Field Descriptions".
