The newfs command is a friendlier version of the mkfs command that is used to create file systems. The newfs command is located in the /usr/sbin directory.
The syntax is:
newfs [-Nv] [mkfs_options] raw_device |
Table 32-3 describes the options and arguments to the newfs command.
Table 32-3 The newfs Command Options and Arguments|
Option |
Description |
N |
Displays the file system parameters that would be used in creating the file system without actually creating it. This option does not display the parameters used to create an existing file system. |
-v |
Displays the parameters that are passed to the mkfs command and creates the file system, unless used with the -N option. |
mkfs-options |
Use the following options to set the parameters passed to the mkfs command. The options are listed below in the order they are passed to mkfs. Separate the options with spaces without any preceding keywords. |
-s size |
The size of the file system in sectors. The default is automatically determined from the disk label. |
-t ntrack |
The number of tracks per cylinder on the disk. The default is determined from the disk label. |
-b bsize |
The logical block size in bytes to use for data transfers. Specify the size of 4096 or 8192 (4 or 8 Kbytes). The default is 8192 bytes (8 Kbytes). |
-f fragsize |
The smallest amount of disk space in bytes that is allocated to a file. Specify the fragment size in powers of two in the range from 512 to 8192 bytes. The default is 1024 bytes (1 Kbyte). |
-c cgsize |
The number of disk cylinders per cylinder group. This number must be in the range 1 to 32. The default is 16. |
-m free |
The minimum percentage of free disk space to allow. The default is ((64 Mbytes/partition size) * 100), rounded down to the nearest integer and limited between 1% and 10%, inclusively. |
-r rpm |
The speed of the disk, in revolutions per minute. The default is 3600. This parameter is converted to revolutions per second before it is passed to mkfs. |
-i nbpi |
The number of bytes per inode to use in computing how may inodes to create. The default is 2048. |
-o opt |
Optimization type to use for allocating disk blocks to files: space or time. The default is time. |
-a apc |
The number of alternate blocks per disk cylinder (SCSI devices only) to reserve for bad block placement. The default is 0. |
-d gap |
(Rotational delay) The expected minimum number of milliseconds it takes the CPU to complete a data transfer and initiate a new data transfer on the same disk cylinder. The default is 4. |
-d nrpos |
The number of different rotation positions in which to divide a cylinder group. The default is 8. |
-C maxcontig |
The maximum number of blocks, belonging to one file, that will be allocated contiguously before inserting a rotational delay. The default varies from drive to drive. Drives without internal (track) buffers (or drives/controllers that don't advertise the existence of an internal buffer) default to 1. Drives with buffers default to 7. This parameter is limited in the following way: blocksize x maxcontig must be <= maxphys maxphys is a read-only kernel variable that specifies the maximum block transfer size (in bytes) that the I/O subsystem is capable of satisfying. (This limit is enforced by mount, not by newfs or mkfs.) This parameter also controls clustering. Regardless of the value of rotdelay, clustering is enabled only when maxcontig is greater than 1. Clustering allows higher I/O rates for sequential I/O and is described in tunefs(1M). |
raw_device |
The special character (raw) device file name of the partition to contain the file system. This argument is required. |
This newfs example uses the -N option to display file system information, including the backup superblocks.
# newfs -N /dev/rdsk/c0t0d0s0
/dev/rdsk/c0t0d0s0: 37260 sectors in 115 cylinders of 9 tracks, 36 sectors
19.1MB in 8 cyl groups (16 c/g, 2.65MB/g, 1216 i/g)
superblock backups (for fsck -b #) at:
32, 5264, 10496, 15728, 20960, 26192, 31424, 36656,
