Become superuser.
Also, there must be a mount point on the local system to mount a file system. A mount point is a directory to which the mounted file system is attached.
Mount a file system listed in the /etc/vfstab file.
# mount mount-point |
mount-point |
Specifies an entry in the mount point or device to mount field in the /etc/vfstab file. It is usually easier to specify the mount point. |
The following example mounts the /usr/openwin file system listed in the /etc/vfstab file.
# mount /usr/openwin |
