Become superuser.
Also, there must be a mount point on the local system to mount a file system. A mount point is a directory to which the mounted file system is attached.
Edit the /etc/vfstab file and add an entry.
Since the root (/) file system is mounted read-only by the kernel during the boot process, only the remount option (and options that can be used in conjunction with remount) affect the root (/) entry in the /etc/vfstab file.
See Table 28-4 for detailed information about the /etc/vfstab field entries. Make sure that you:
Separate each field with white space (a space or a tab).
Enter a dash (-) if a field has no contents.
Save the changes.
The following example mounts the disk slice /dev/dsk/c0t3d0s7 as a UFS file system attached to the mount point directory /files1 with the default mount options (read/write). It specifies the raw character device /dev/rdsk/c0t3d0s7 as the device to fsck. The fsck pass value of 2 means that the file system will be checked, but not sequentially.
#device device mount FS fsck mount mount #to mount to fsck point type pass at boot options # /dev/dsk/c0t3d0s7 /dev/rdsk/c0t3d0s7 /files1 ufs 2 yes - / - /tmp/newroot lofs - yes - |
The following example mounts the directory /export/man from the system pluto as an NFS file system on mount point /usr/man. It does not specify a device to fsck or a fsck pass because it's an NFS file system. In this example, mount options are ro (read-only) and soft. For greater reliability, specify the hard mount option for read/write NFS file systems.
#device device mount FS fsck mount mount #to mount to fsck point type pass at boot options pluto:/export/man - /usr/man nfs - yes ro,soft |
The following example mounts the root (/) file system on a loopback mount point named /tmp/newroot. It specifies yes for mount at boot, no device to fsck, and no fsck pass number. LOFS file systems must always be mounted after the file systems used to make up the LOFS file system.
#device device mount FS fsck mount mount #to mount to fsck point type pass at boot options # / - /tmp/newroot lofs - yes - |
