Table 28-3 describes the commonly used mount options that you can specify with the -o option of the mount command. If you specify multiple options, separate them with commas (no spaces). For example, -o ro,nosuid.
For a complete list of mount options for each file system type, refer to the specific mount command man pages (for example, mount_ufs(1M)).
Table 28-3 Commonly Used -o Mount Options|
Option |
File System |
Description |
bg | fg |
NFS |
If the first attempt fails, retries in the background (bg) or in the foreground (fg). The default is fg. |
f |
UFS |
Fakes an entry in /etc/mnttab, but doesn't really mount any file systems. |
hard | soft |
NFS |
Specifies the procedure if the server does not respond. soft indicates that an error is returned. hard indicates that the retry request is continued until the server responds. The default is hard. |
intr | nointr |
NFS |
Specifies whether keyboard interrupts are allowed to kill a process hung while waiting for a response on hard-mounted file systems. The default is intr (interrupts allowed). |
largefiles | nolargefiles |
UFS |
Enables you to create file systems containing files larger than 2 Gbytes. The largefiles option means that a filesystem mounted with this option may contain files larger than 2 Gbytes, but it is not a requirement. The default is largefiles. |
logging | nologging |
UFS |
Enables logging for the file system. UFS logging is the process of storing transactions (changes that make up a complete UFS operation) into a log before the transactions are applied to the UFS file system. Because the file system can never become inconsistent, fsck can be bypassed, which reduces the time to reboot a system if it crashes, or after an unclean halt. The log is allocated from free blocks on the file system, and is sized approximately 1 Mbyte per 1 Gbyte of file system, up to a maximum of 64 Mbytes. The default is nologging. |
m |
CacheFS, NFS, PCFS, S5FS, UFS |
Mounts the file system without making an entry in /etc/mnttab. |
noatime |
UFS |
Ignores access time updates on files, except when they coincide with updates to the ctime or mtime. See stat(2). This option reduces disk activity on file systems where access times are unimportant (for example, a Usenet news spool). The default is normal access time (atime) recording. |
remount |
NFS, S5FS, UFS |
Remounts a read-only file system as read-write (using the rw option). This option can be used only in conjunction with the f, logging | nologging, and m options. This option works only on currently mounted read-only file systems. |
retry=n |
NFS |
Retries the mount operation when it fails. n is the number of times to retry. |
ro | rw |
CacheFS, NFS, PCFS, UFS, S5FS |
Specifies read/write or read-only. If you do not specify this option, the default is read/write. |
suid | nosuid |
CacheFS, HSFS, NFS, S5FS, UFS |
Allows or disallows setuid execution The default is to allow setuid execution. |
