List all the processes that are using the file system, so you know which processes you are going to stop.
# fuser -c [ -u ] mount-point |
-c |
Reports on files that are mount points for file systems and any files within those mounted file systems. |
-u |
Displays the user login name for each process ID. |
mount-point |
The name of the file system for which you want to stop processes. |
Stop all processes for the file system.
You should not stop a user's processes without warning.
# fuser -c -k mount-point |
A SIGKILL is sent to each process using the file system.
Verify that there are no processes using the file system.
# fuser -c mount-point |
The following example stops process 4006c that is using the /export/home file system.
# fuser -c /export/home /export/home: 4006c # fuser -c -k /export/home /export/home: 4006c # fuser -c /export/home /export/home: |
