Table 26-3 provides guidelines on mounting file systems based on how you use them.
Table 26-3 Determining How to Mount File Systems
You can mount a CD-ROM containing a file system by simply inserting it into the drive (Volume Management will automatically mount it). You can mount a diskette containing a file system by inserting it into the drive and running the volcheck command. See Part IV for more information.
