Check the file system.
# fsck -m /dev/rdsk/device-name |
In this command, the state flag in the superblock of the file system you specify is checked to see whether the file system is clean or requires checking.
If you omit the device argument, all the UFS file systems listed in /etc/vfstab with a fsck pass value greater than 0 are checked.
The following example shows that the file system needs checking.
# fsck -m /dev/rdsk/c0t0d0s6 ** /dev/rdsk/c0t0d0s6 ufs fsck: sanity check: /dev/rdsk/c0t0d0s6 needs checking |
