Boot to run level 3 by using the boot(1M) command.
ok boot |
The automatic boot procedure displays a series of startup messages, and brings the system to run level 3.
Verify the system boots to run level 3.
The login prompt is displayed when the boot process has finished successfully.
hostname console login: |
The following example displays the messages from booting a system to run level 3.
ok boot Resetting ... SPARCstation 10 (1 X 390Z50), Keyboard Present ROM Rev. 2.14, 32 MB memory installed, Serial #number. Ethernet address #number, Host ID: number. Boot device: /iommu/sbus/espdma@f,400000/esp@f,800000/sd@3,0 File and args: SunOS Release 5.7 Version generic [UNIX(R) System V Release 4.0] Copyright (c) 1983-1998, Sun Microsystems, Inc. configuring network interfaces: le0. Hostname: venus The system is coming up. Please wait. add net default: gateway 129.152.75.248 NIS domainname is solar.com starting rpc services: rpcbind keyserv ypbind done. Setting netmask of le0 to 255.255.255.0 Setting default interface for multicast: add net 224.0.0.0: gateway venus syslog service starting. Print services started. volume management starting. The system is ready. venus console login: |
