During this phase, you can determine the way in which the system is booted.
The Boot Solaris menu allows you to select the device from which to boot the Solaris release. You can also perform optional tasks, such as view and edit autoboot and property settings. Once a boot device is selected and you choose Continue, the Solaris kernel will begin to boot.
Boot Solaris Select one of the identified devices to boot the Solaris kernel and choose Continue. To perform optional features, such as modifying the autoboot and property settings, choose Boot Tasks. An asterisk (*) indicates the current default boot device. > To make a selection use the arrow keys, and press Enter to mark it [X]. [ ] DISK: Target 0, IMPRIMIS 94241-7 0888 on Adaptec 1740/1742 SCSI controller in EISA Slot 4 [ ] CD : Target 2, TOSHIBA CD-ROM XM-3501TA 3054 on Adaptec 1740/1742 SCSI controller in EISA Slot 4 [ ] NET : SMC EtherCard Elite32C Ethernet adapter in EISA Slot 6 F2_Continue F3_Back F4_Boot Tasks F6_Help |
This menu appears each time you boot Solaris from the local disk. Let the five-second timeout elapse if you want to boot the default Solaris kernel. If you want to boot with different options, select an appropriate option before the timeout period elapses.
<<< Current Boot Parameters >>>
Boot path: /eisa/eha@1,4000/sd@0,0:a
Boot args:
Type b [file-name] [boot-flags] <ENTER> to boot with options
or i <ENTER> to enter boot interpreter
or <ENTER> to boot with defaults
<<< timeout in 5 seconds >>>
Select (b)oot or (i)nterpreter:
