System Administration Guide, Volume I
How to Shut Down a Server
  1. Become superuser.
  2. Find out if users are logged into the system.
    # who
    A list of all logged-in users is displayed. You may want to send mail or broadcast a message to let users know that the system is being shut down.
  3. Shut down the system by using the shutdown(1M) command.
    # shutdown -iinit-state -ggrace-period -y
    -iinit-state
    Brings the system to an init state different from the default of S. The choices are 0, 1, 2, 5, and 6.
    -ggrace-period
    Indicates a time (in seconds) before the system is shut down. The default is 60 seconds.
    -y
    Continues to shut down the system without intervention; otherwise, you are prompted to continue the shutdown process after 60 seconds.
  4. If you are asked for confirmation, type y.
    Do you want to continue? (y or n): y
    If you used the shutdown -y command, you will not be prompted to continue.
  5. Type the superuser password, if prompted.
    Type Ctrl-d to proceed with normal startup,
    (or give root password for system maintenance): xxx
  6. After you have finished the system administration tasks, press Control-d to return to the default run system level.
  7. Use the following table to verify the system is at the run level specified in the shutdown command.
    If the System Was Brought To ...
    The SPARC System Prompt Should Be ...
    The x86 System Prompt Should Be ...
    Run level S (single-user state)
    Run level 0 (power-down state)
    ok or >
    type any key to continue
    Run level 3 (multiuser state with remote resources shared)
    hostname console login:
Example--Bringing a SPARC System to Run Level S (Server)
In the following example, the shutdown is used to bring a SPARC system to run level S (single-user state) in 3 minutes.
# who
root       console      Jun 10 14:15
# shutdown -g180 -y
Shutdown started.    Wed Jun 10 14:15:25 MDT 1998
Broadcast Message from root (console) on mars Wed Jun 10 14:15:26...
The system mars will be shut down in 3 minutes
Broadcast Message from root (console) on mars Wed Jun 10 14:17:58...
The system mars will be shut down in 30 seconds
INIT: New run level: S
The system is coming down for administration.  Please wait.
Unmounting remote filesystems: /vol nfs done.
Print services stopped.
syslogd: going down on signal 15
Killing user processes: done.
INIT: SINGLE USER MODE
Entering System Maintenance Mode ...
Example--Bringing a SPARC System to Run Level 0 (Server)
In the following example, the shutdown command is used to bring a SPARC system to run level 0 in 5 minutes without requiring additional confirmation.
# who
kryten     console      Jun 10 14:22
rimmer     pts/1        Jun 10 14:23    (starbug)
pmorph     pts/2        Jun 10 14:24    (bluemidget)
Send mail message to logged-in users
# shutdown -i0 -g300 -y
Shutdown started.    Wed Jun 10 14:30:32 MDT 1998
Broadcast Message from root (console) on pluto Wed Jun 10 14:30:32...
The system will be shut down in 5 minutes
INIT: New run level: 0
The system is coming down.  Please wait.
The system is down.
syncing file systems... [11] [9] [5] done
Program terminated
Type  help  for more information
ok
See "How to Turn Off Power to All Devices" if you are bringing the system to run level 0 to turn off power to all devices.
Example--Rebooting a SPARC System to Run Level 3 (Server)
In the following example, the shutdown command is used to reboot a SPARC system to run level 3 in 2 minutes without requiring additional confirmation.
# who
kryten     console      Jun 10 14:35
rimmer     pts/1        Jun 10 14:40    (starbug)
pmorph     pts/2        Jun 10 14:45    (bluemidget)
# shutdown -i6 -g120 -y
Shutdown started.    Wed Jun 10 14:34:26 MDT 1998
Broadcast Message from root (console) on pluto Wed Jun 10 14:34:26 MDT 1998
The system will be shut down in 1 minute
Changing to init state 6 - please wait
INIT: New run level: 6
The system is down.
rebooting...
pluto console login:
Where to Go From Here
Regardless of the reason for shutting down the system, you'll probably want to return to run level 3 where all file resources are available and users can log in. See Chapter 8, Booting a SPARC System (Tasks) or Chapter 9, x86: Booting a System (Tasks) for instructions on bringing a system back to a multiuser state.
