You can format a DOS diskette on a SPARC or x86 Solaris platform. The steps are similar, except that instead of a SunOS file system being placed on the diskette, a DOS file system, either MS-DOS or NEC-DOS, is put on the file system.
Formatting a diskette erases any pre-existing content.
Quit File Manager.
File Manager automatically displays a formatting window when you insert an unformatted diskette. Unfortunately, File Manager formatting is unreliable. To avoid the window, quit from File Manager. If you prefer to keep File Manager open, quit the formatting window when it appears.
Make sure the diskette is not write-protected.
On both 3.5-inch and 5.25 inch diskettes, write-protection is controlled by a small tab in either the lower left or lower right corner. If you can see through the square hole behind the tab, the diskette is write-protected. If the hole is covered by the tab, the diskette is write-enabled. (If you need to eject the diskette to examine it, simply type eject floppy in a shell.)
Insert the diskette.
Make sure the diskette is completely inserted. It must drop down into the drive.
$ fdformat -v -U [density-options convenience-options] |
-v |
Verifies whether the diskette was formatted correctly. |
-U |
Unmounts the diskette if it is mounted. |
density-options |
If the drive density is 1.44 Mbytes, density-options are: |
-d |
Formats at 1.44 Mbytes for MS-DOS. |
-d -D |
Formats at 720 Kbytes for MS-DOS. |
-t nec -M |
Formats at 1.2 Mbytes for NEC-DOS. |
A complete list of density-options appears in Table 13-3. |
convenience-options |
-e |
Ejects the diskette when done formatting. |
-f |
Does not ask for confirmation before formatting. |
-b label |
Name for the diskette. label must be eight characters or less, upper or lower case. |
-z |
Lists all the options to the fdformat command, but does not format the diskette. |
If you try to format a 720 Kbyte (DD) diskette for 1.44 Mbytes, fdformat will not stop you unless you include the -v option. With the -v option, fdformat will format the diskette, but the verification will catch the error and notify you with the following message: fdformat: check diskette density, I/O error
The fdformat command displays a confirmation message, indicating the type of formatting to be performed:
Formatting 1.44 M in /vol/dev/rdiskette0/unformatted Press return to start formatting floppy. |
Select one of the options in the table below.
To ... |
Press ... |
Confirm the type of formatting |
Return (unless you used the -f option in the previous step, in which case no confirmation is necessary). |
Cancel formatting |
Control-c. |
As the formatting progresses, a series of dots is displayed. As the verification progresses, a series of V's appears beneath the dots. When the series stops, the formatting is complete and the diskette is ready for use on a DOS system.
Run the volrmmount(1) command using the -i option to notify Volume Management that the diskette is inserted.
$ volrmmount -i floppy0 |
Volume Management mounts the diskette under /floppy/floppy0.
The following example formats a 1.44 Mbyte MS-DOS diskette and assigns the diskette the name myfiles:
$ fdformat -v -U -b myfiles Formatting 1.44 M in /vol/dev/rdiskette0/unformatted Press return to start formatting floppy. [ Return ] ...................................................... vvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvv |
