In the following example, the processes 6400c and 6399c are accessing the /floppy/floppy0 directory, and the process owners are root and smith, respectively.
# fuser -u /floppy/floppy0 /floppy/floppy0: 6400c(root) 6399c(smith) |
You can kill the processes individually (as superuser), or you can use the fuser command with the -k option, which kills all the processes accessing that file system. The fuser command may not always identify all the killed processes. To be sure, run it again with the -u option.
# fuser -u -k /floppy/floppy0 /floppy/floppy0: 6400c(root)Killed 6399c(smith)Killed |
