System Administration Guide, Volume I
Add Customized User Initialization Files
Although you can't create customized user initialization files with Admintool, you can populate a user's home directory with user initialization files located in a specified "skeleton" directory.
You can customize the user initialization templates in the /etc/skel directory and then copy them to users' home directories.
