The folder view will show a folder and all the files and folders in that folder.
Change to the folder that you want to view.
Choose Set View Options from the View menu.
Select By Single Folder in the Show box.
To implement the chosen options and close the Set View Options dialog box, click OK. To implement the chosen options and leave the Set View Options dialog box open, click Apply.
You can alter the appearance of files and folders in the folder view by changing the settings in the Show box in the Set View Options dialog box. Changes to the preferences are only for the current session. To make them permanent, see "To Save the Current Preferences as Your Default".
