The page description language used to create some documents may not include page size information. This can cause page boundaries to display incorrectly. To change the displayed page size:
Choose Page Viewing Controls from the View menu.
The Page Viewing Controls dialog box appears.
Select the size of the page you want for displaying the current document.
Click OK to apply your choices and close the dialog box.
See "Print Dialog Box" for information on changing the size of the printed page.
