You can use two of the Format menu options in the Compose window to make formatting changes to the message you are composing.
Word Wrap |
Toggles the text entry mode that causes lines to automatically wrap at the edge of the message. Note that if you have Word Wrap on and the recipient's window is of a different size, you may cause display problems. |
Settings |
Displays a dialog box for setting margins and paragraph alignment, and applying format settings to your message. |
For more information on editing functions, see Chapter 10, Using Text Editor .
