Choose Find/Change from the Edit menu or press Control+F.
Type the text you want to delete in the Find field.
Leave the Change To field blank.
Press Return or click Find to locate the next occurrence.
Click Change to delete a single occurrence.
To find and change additional occurrences, click Find and then Change.
Or, click Change All to replace all occurrences.
Click Close when you are done.
