There are several ways you can start a Terminal window:
From the Front Panel
From Application Manager
From File Manager
From the Window Menu of Another Terminal
From Address Manager with a host selected
Select the This Host control on the Hosts subpanel.
Or, click the activity indicator (globe) control on the workspace switch.
The Go dalog box is displayed.
Type an IP address such as 129.156.120.179 or the @ symbol followed by a hostname (for example, @jupiter) for the host on which you want to run the terminal session.
Click OK.
Click the Desktop_Apps control on the Front Panel.
Double-click the Terminal icon (you may have to scroll down to see it).
Click the File Manager control on the Front Panel.
The File Manager window appears.
Choose Open Terminal from the File Manager File menu.
Choose New from the Window menu of an existing Terminal window.
An exact replica of the Terminal window appears.
With the IP address of the required host displayed inthe scrolling pane of Address Manager, choose Terminal from the Actions menu.
