You can modify any of the actions available on your system, including built-in actions.
Use caution when modifying the built-in action database. The built-in actions are designed to work well with the desktop applications.
Locate the definition of the action you want to modify.
The default locations for action definitions are:
Built-in actions: /usr/dt/appconfig/types/language
System-wide actions: /etc/dt/appconfig/types/language
Personal actions: HomeDirectory/.dt/types
Your system might include additional locations. To see a list of the locations your system uses for actions, type the command:
dtsearchpath -v
Your system uses the directories listed under DTDATABASESEARCHPATH.
If necessary, copy the text of the action definition to a new or existing file in one of these directories:
You must copy built-in actions, since you should not edit files in the /usr/dt/appconfig/types/language directory.
Edit the action definition.
When you are done editing, save the file.
Double-click Reload Actions in the Desktop_Tools application group.
