When the user invokes an action, the system searches the database for a matching action name. When more than one action exists with that name, the system uses precedence rules to decide which one to use.
If no other precedence rules apply, the precedence is based on the location of the definition. The following list is ordered from higher to lower precedence:
Personal actions (HomeDirectory/.dt/types)
System-wide local actions (/etc/dt/appconfig/types/language)
System-wide remote actions (hostname:/etc/dt/appconfig/types/language). The remote hosts searched are those listed in the application search path.
Built-in actions (/usr/dt/appconfig/types/language)
Within a given directory, the *.dt files are read in alphabetical order.
Actions restricted by ARG_CLASS, ARG_TYPE, ARG_MODE, or ARG_COUNT have precedence over unrestricted actions. (The default for these four fields is *.)
Where more than one restriction applies, the precedence order from high to low is:
ARG_CLASS
ARG_TYPE
ARG_MODE
ARG_COUNT
Where more than one restricted ARG_COUNT exists, the precedence order from high to low is:
Specific integer value n
<n
>n
For example, consider the following portions of action definitions:
ACTION EditGraphics # EditGraphics-1 { ARG_TYPE XWD ... }
ACTION EditGraphics # EditGraphics-2 { ARG_COUNT 0 ... }
ACTION EditGraphics # EditGraphics-3 { ARG_TYPE * ... }
Double-clicking the EditGraphics action icon starts EditGraphics-2 because no argument is provided and ARG_COUNT 0 has precedence. When an XWD-type file argument is provided, EditGraphics-1 is used because it specified the XWD ARG_TYPE. EditGraphics-3 is used for all other file arguments.
