To change search settings, click SELECT on the Search Settings button. In the Search Settings window you can specify various options to control the results of your searches.
Search Library by: Text and Titles searches all text included in your Library, while Titles Only searches only book and chapter titles, and section and subsection headings.
Sort Findings by: Relevance Only simply lists all documents found in order of relevance, regardless of the books they appear in. Relevance and Book means the documents found will be listed grouped by book, with topics within a given book listed by relevance.
Limit Findings to: Click SELECT to increase or decrease the default number of 30 findings per search.
Click SELECT on Apply to preserve your settings, or click SELECT on Reset to undo your choices and restore the previous ones.
